THICKNESS = 2 inch XXHEAVY pipe wall thickness .625"
WELD TYPE = groove
JOINT TYPE = BUTT WELD
POSITION = 6G pipe OPEN ROOT WITH 1/8” GAP AND ZERO LAND
AMPERAGE = 124
FILLER WIRE = 1/8” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = MANUAL
POST FLOW = 10
ADDITIONALSETTINGS =
TIPS: EXTEND ELECTRODE ENOUGH TO GET A DECENT ANGLE SO THAT WALKING THE CUP OR FREEHAND WELDING BOTH WORK WELL …MOVE QUICKLY ACROSS CENTER OF WELD
