TIG CARBON STEEL 2 INCH SCHEDULE 40 .150" WALL THICKNESS SOCKET WELD ROOT
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
WELD PROCESS = TIG, GTAW, GAS TUNGSTEN ARC WELDING,  LIFT ARC TIG
METAL TYPE = carbon steel
THICKNESS = 2 inch schedule 40 pipe wall thickness .150"
WELD TYPE = FILLET   WELD ROOT PASS
JOINT TYPE = SOCKET WELD ROOT
POSITION = 5G  IN TRIPOD VISE
AMPERAGE = 140
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 15-20 CFH argon
CUP SIZE =  6
PRE FLOW =
POST FLOW =  10
TIPS: EXTEND ELECTRODE ENOUGH TO GET A TORCH ANGLE SO THAT WALKING THE CUP OR FREEHAND WELDING BOTH WORK WELL.
USUALLY AROUND THE SAME AS INSIDE DIAMETER OF CUP OR SLIGHTLY LESS
tig welding socket weld
