TIG WELDING CARBON STEEL 1G 18GA BUTT
scroll down for details and settings for tig welding 18 ga steel butt joint
METAL TYPE = CARBON STEEL
THICKNESS = .043”
WELD TYPE = GROOVE WELD
JOINT TYPE = BUTT
POSITION = 1G FLAT
AMPERAGE = MACHINE SET TO 55 AMPS using FOOT PEDAL
FILLER WIRE = .045” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
TIPS: KEEP A TIGHT ARC
