TIG CARBON STEEL11GA COLD ROLLED PULSE TEE 2F
scroll down for settings
Once and for all pushing vs pulling mig welding
Video of Dual Shield Flux Core vs 7018 Stick Electrode vertical uphill using an Esab Rebel 285
TIG Welder Settings for Steels and Aluminum with Quick Videos Showing settings and results
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 2F HORIZONTAL
AMPERAGE = MACHINE SET TO 131AMPS CONTROLLED WITH PEDAL TO 128 AMPS MAX
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20 CFH argon
CUP SIZE = 8
ADDITIONAL SETTINGS = 1 pulse per second, 55% pulse on time, 25% background
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
var l = window.location.href,
d = document;
