TIG CARBON STEEL MONSTER COUPON 6G Root PASS
Did you know?..
THICKNESS = 2 inch  XXHEAVY pipe wall thickness .625"
WELD TYPE = groove
JOINT TYPE = BUTT WELD
POSITION = 6G pipe
OPEN ROOT WITH 1/8” GAP AND ZERO LAND
AMPERAGE = 95-105
FILLER WIRE = 3/32” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW =  MANUAL
POST FLOW =  10
