TIG BRAZING CAST IRON WITH ALUMINUM BRONZE FILLER ON AC
Scroll down for exact settings used for tig brazing cast iron using aluminum bronze filler metal on AC
METAL TYPE = CAST IRON VISE
THICKNESS =  1 INCH
WELD TYPE =  BUILD UP
JOINT TYPE =  BUILD UP TO REPLACE BROKEN MOUNTING LUG
POSITION = FLAT
AMPERAGE = MACHINE SET TO 150  AMPS CONTROLLED WITH FOOT PEDAL ( ACTUAL AMPERAGE 125-140)
TUNGSTEN = 2% LANTHANATED, 3/32"FILLER WIRE = 3/32” ALUMINUM BRONZE ERCUAL-A2
POLARITY = AC
GAS FLOW = 20 CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =    AC BALANCE SET TO 75 (25% CLEANING)PREHEAT OF 400F PRIOR TO WELDING
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
Maintain temperature of 400F
