Tig Brazing carbon steel with Aluminum Bronze filler rod on AC
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = FILE HANDLE
THICKNESS =  .125"
WELD TYPE = SURFACE BUILD UP
JOINT TYPE = EDGE BUILD UP
POSITION = FLAT
AMPERAGE = MACHINE SET TO 120  AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 3/32” ALUMINUM BRONZE ERCUAL-A2
POLARITY = AC
GAS FLOW = 20 CFH argon
CUP SIZE =  8
ADDITIONAL SETTINGS =    AC BALANCE SET TO 70 (30% CLEANING)
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
tig-brazing-carbon-file-aluminum-bronze-welderskills-vimeo
