TIG BRAZE CARBON STEEL THIN WALL .063" SQUARE TUBE SILICON BRONZE PULSE SETTINGS
scroll down for settings
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = COLD ROLLED STEEL
THICKNESS = .063"
WELD TYPE = FILLET WELD
JOINT TYPE = TEE
POSITION = 2F
AMPERAGE = 120 AMPS USING PULSE SETTINGS CONTROLLED WITH FOOT PEDAL ACTUAL AMPERAGE READOUT WAS 65-75
GAS FLOW = 25 CFH argon
CUP SIZE = 12
ADDITIONAL SETTINGS = PULSE SETTINGS 2PPS, 33% BACKGROUND CURRENT, 33% ON TIME
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
TIPS: KEEP A FAIRLY TIGHT ARC AND WATCH TORCH ANGLE
