TIG BRAZE CARBON STEEL .100" THICK TUBE TO SHEET 100 AMPS SILICON BRONZE FILLET
SCROLL DOWN FOR SETTINGS
METAL TYPE = COLD ROLLED STEEL
THICKNESS =  .100"
WELD TYPE = FILLET WELD
JOINT TYPE = TEE, TUBE TO PLATE
POSITION = 2F
AMPERAGE = MACHINE SET TO 100  AMPS CONTROLLED WITH FOOT PEDAL
TUNGSTEN = 2% LANTHANATED, 3/32"FILLER WIRE = 3/32” SILICON BRONZE
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
gas lens cups help a lot for tig brazing with silicon bronze filler rod.  larger size cups like the jazzy10 or furick 12 help in preventing oxidation of the puddle.
