METAL TYPE = COLD ROLLED STEEL
THICKNESS = .100"
WELD TYPE = FILLET WELD
JOINT TYPE = CORNER
POSITION = 2F
AMPERAGE = 109 AMPS USING PULSE SETTINGS CONTROLLED WITH FOOT PEDAL
TUNGSTEN = 2% LANTHANATED, 3/32"FILLER WIRE = 1/16” SILICON BRONZE
GAS FLOW = 25 CFH argon
CUP SIZE = 12
PULSE SETTINGS 2PPS, 30% BACKGROUND CURRENT, 50% ON TIME
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
TIPS: KEEP A FAIRLY TIGHT ARC AND WATCH TORCH ANGLE
