TIG BRAZING CARBON STEEL 14 GA OUTSIDE CORNER SILICON BRONZE NO PULSE
Scroll down for exact tig brazing settings
METAL TYPE = COLD ROLLED STEEL
THICKNESS = .100"
WELD TYPE = FILLET WELD
JOINT TYPE = CORNER
POSITION = 2F
AMPERAGE = 65 AMPS CONTROLLED WITH FOOT PEDAL
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
TIPS: KEEP A FAIRLY TIGHT ARC AND WATCH TORCH ANGLEAim for an arc length that is equal or less than the diameter of your tungsten electrode.Torch angle can be forgiving provided your arc length is tight.
a larger cup size like a jazzy10 or furick 12 can make a big difference when you are tig brazing with silicon bronze filler rod.
Did you know?...
***Its Easy to sign up
No Ads, No BS style
