TIG BRAZE CARBON STEEL .100" THICK 3/32 SILBRO 2F FILLET LAYWIRE 100 AMPS
Scroll Down for exact tig braze settings used
METAL TYPE = COLD ROLLED STEEL
THICKNESS =  .100"
WELD TYPE = FILLET WELD
JOINT TYPE = TEE
POSITION = 2F
AMPERAGE = MACHINE SET TO 100  AMPS CONTROLLED WITH FOOT PEDAL
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
TIPS:
KEEP A FAIRLY TIGHT ARC AND WATCH TORCH ANGLE
sometimes it is very helpful to use a large size cup like 10 or 12 with gas lens and extra diffusers.
A larger gas envelope helps keep the puddle clean and also kees the hot tip of the filler rod free from oxidation and scum.
Did you know?...
***Its Easy to sign up
No Ads, No BS style
