METAL TYPE = 304 STAINLESS STEEL
THICKNESS = 2 INCH
WELD TYPE = FILLET
JOINT TYPE = SOCKET WELD MOCK UP
POSITION = 2F
AMPERAGE = 170 AMPS CONTROLLED WITH FOOT PEDAL
FILLER WIRE = 1/8” ER308L
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = .2 SEC
POST FLOW = 11 SEC
TIPS: GET MOVING TO AVOID HEAT BUILDUP LET COOL TO BELOW 250F BETWEEN PASSES TO MAINTAIN STAINLESS PROPERTIES
Aim for an arc length that is equal or less than the diameter of your tungsten electrode. Torch angle can be forgiving provided your arc length is tight.
