suggested setting for FCAW when welding carbon steel
by Jake
(Seattle ,WA)
What voltage should I run when welding the following in all positions: 3/16", 3/8" and 1"?
there are so many different specs of flux core wire that settings vary. If you can find the spec on the wire spool, you can find some pretty good settings here
http://www.lincolnelectric.com/assets/en_US/Products/Consumable_Flux-CoredWires-Gas-Shielded-UltraCore-UltraCore712A80/c110b.pdf
