METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD HOT PASS
JOINT TYPE = BUTT
POSITION = 4G OVERHEAD PLATE
AMPS = 135-140 AMPS
ELECTRODE = 7010 5/32"
TIPS: WHIP AND PAUSE TECHNIQUE TO CONTROL PUDDLE
