METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE weld 2 BEAD COVER PASS
JOINT TYPE = BUTT
POSITION =HYBRID OVERHEAD/VERTICAL AT 45 DEGAMPS = 110 AMPS
ELECTRODE = 7018 1/8”EXCALIBUR
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
