STICK WELD CARBON STEEL 3/8" PLATES 5/32" 7010 HOT PASS BRANCH PRACTICE
scroll down for settings
Did you know?..
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = BRANCH PRACTICE PLATE HOT PASS
JOINT TYPE = BUTT/FILLET
POSITION = 4F OVERHEAD
AMPS = 140-145 AMPS
ELECTRODE = 7010 5/32"
ADDITIONAL SETTINGS = DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS. ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK. TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
