STICK CARBON STEEL MONSTER COUPON 7018 3/32 6G SETTINGS
Did you know?..
METAL TYPE = CARBON STEEL 2 INCH XX HEAVY WALL
THICKNESS = .625” WALL THICKNESS
WELD TYPE = GROOVE
JOINT TYPE = BUTT
POSITION = 6G PIPE TEST uphill
AMPS = 80-90 AMPS
ELECTRODE = 7018 3/32"
AMPERAGE LISTED SHOULD GET YOU IN THE BALL PARK.
