STICK WELDING CARBON STEEL 3/8" 2G PLATE 7018 1/8"
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD 35 DEGREE BEVELS
JOINT TYPE = BUTT
POSITION = 2G
AMPS = 120 AMPS
ELECTRODE = 7018 1/8"
Did you know?..
