STICK WELDING CARBON STEEL 2F TEE 7018 1/8" MULTIPASS
scroll down for settings
Did you know?..
2F TEE 7018 MULTIPASS 18 130 AMPS WS END.mov
THICKNESS = 1/4"
WELD TYPE = Fillet weld MULTI PASS
JOINT TYPE = TEE
POSITION = 2F
AMPS = 130 AMPS
ELECTRODE = 7018 1/8"
TIPS:SET THE AMPERAGE HOT ENOUGH TO NOT STICK THE ROD WHEN YOU HOLD A TIGHT ARC…THEN HOLD A TIGHT ARC.DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
stick welding smaw tee 2f
