STICK WELDING CARBON STEEL 3/8" PLATE OVERHEAD COVER PASS WITH 5/32-7010
wtt-banner-free-3pk-tungsten
 scroll down for settings
This practice plate simulates the bottom of a downhill pipe weld...preparing for Downhill pipe welding with 5/32" 7010 hyp rods
Did you know?..
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD
JOINT TYPE = BUTT
POSITION = 4G OVERHEAD PLATE
AMPS = 135-140 AMPS
ELECTRODE = 7010 5/32"
TIPS: WHIP AND PAUSE TECHNIQUE TO CONTROL PUDDLE
AMPERAGE SHOWN SHOULD GET YOU IN THE BALL PARK.
