STICK WELDING CARBON STEEL 3/8" PLATE OPEN ROOT SETTINGS 6010 1/8" DOWNHILL
scroll down for settings
Did you know?..
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD  ROOT PASS 1/16 GAP, 1/16 LAND
JOINT TYPE = BUTT
POSITION = 3G   DOWNHILL PLATE
AMPS = 90 AMPS
ELECTRODE = 6010 1/8"
TIPS:   DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
stick welding 6010 root
