Stick Welding Carbon steel 3/8"plate 7016 3/32" hot pass
scroll down for settings
Did you know?..
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE
JOINT TYPE = BUTT
POSITION = HYBRID VERTICAL OVERHEAD AT 45 DEG FOR PRACTICE
AMPS = 80 AMPS
ELECTRODE = 7016 3/32"
TIPS:
7016 stick smaw
