Stick Welding Carbon Steel Pipe 3/8" wall 12 inch Downhill 7010 3/16"
scroll down for settings
Did you know?..
METAL TYPE = CARBON STEEL
THICKNESS = 3/8” WALL 12 INCH PIPE
WELD TYPE = 12 INCH PIPE DOWNHILL HOT PASS 3/32" GAP, 3/32" LAND
JOINT TYPE = BUTT
POSITION = 5G DOWNHILL
AMPS = 155 AMPS
ELECTRODE = 7010 3/16"
TIPS:   DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
stick welding pipe downhill
