STICK WELDING CARBON STEEL PIPE .430" WALL THICKNESS 6g pipe 7018 1/8" fill PASS 6 INCH SCHEDULE80
scroll down for settings
Did you know?..
METAL TYPE = CARBON STEEL 6 INCH SCHED 80 PIPE
THICKNESS = .430” WALL THICKNESS
WELD TYPE = GROOVE HOT PASS
JOINT TYPE = BUTT
POSITION = 6G PIPE TEST uphill
AMPS = 105 AMPS FOR FILL PASS AFTER HOT PASS
ELECTRODE = 7018 1/8"
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.
stick welding 6g pipe 7018
