STICK WELDING 1/4" CARBON STEEL OVERHEAD 7018 1/8" FILLET MULTIPASS
settings for this weld are also listed below...scroll down
METAL TYPE = CARBON STEEL A36
THICKNESS = 3/8"
WELD TYPE = Fillet weld MULTI PASS
JOINT TYPE = TEE
POSITION = 4F OVERHEAD
AMPS = 125 AMPS
ELECTRODE = 7018 1/8""
Did you know?..
stick welding overhead
