Stick Welding Carbon Steel plate overhead 7018 1/8" fill pass
scroll down for settings
Did you know?..
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE weld FILL PASS
JOINT TYPE = BUTT
POSITION =HYBRID OVERHEAD/VERTICAL AT 45 DEG
AMPS = 105 AMPS
ELECTRODE = 7018 1/8”EXCALIBUR
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
weldiing overhead
