STICK WELDING CARBON STEEL 1/4" THICK WITH 7014 1/8 OUTSIDE CORNER
scroll down for details and settings
Arc Length is one of the key things to control in Shielded metal arc welding aka Stick welding.
METAL TYPE = CARBON STEEL
THICKNESS = 1/4"
WELD TYPE = FILLET
JOINT TYPE = OUTSIDE CORNER
POSITION = 1F
AMPS = 110-130 AMPS
ELECTRODE = 7014 1/8"
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.THIS AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
7014 Stick electrodes are rated for welding on all polarity settings
When you need a fairly large fillet weld and you also want a nice smooth weld 7014 rods are great for that.
they lay down more metal than a 6013 with less chance of slag inclusions.
Even using a AC buzz box welder works great with 7014
