STICK CARBON STEEL 3/8" PLATE OVERHEAD CAP BRANCH PRACTICE BEADS 3/16" 7010
scroll down for settings
Did you know?..
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = BRANCH PRACTICE PLATE COVER PASS
JOINT TYPE = BUTT/FILLET
POSITION = OVERHEAD
AMPS = 155 AMPS
ELECTRODE = 7010 3/16"
ADDITIONAL SETTINGS =  DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.
AMPERAGE shown SHOULD GET YOU IN THE BALL PARK.
stick welding overhead 6010
