STICK WELDING BEADS ON 1/4" THICK CARBON STEEL 6013 1/8" RODS
METAL TYPE = CARBON STEEL
THICKNESS = 1/4"
WELD TYPE = BEAD ON PLATE
JOINT TYPE = BEADS ON PLATE
POSITION =  FLAT
AMPS = 115 AMPS
ELECTRODE = 6013 1/8"
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS. AMPERAGE SHOWN SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
