STICK WELDING CARBON STEEL 1/4" THICK 3F LAP with 7018 3/32 EXCALIBUR
welding vertical uphill with 7018 means finding an amperage that is hot enough to get the right penetration but that is not too hot to control.
METAL TYPE = CARBON STEEL
THICKNESS = 1/4"
WELD TYPE = Fillet weld
JOINT TYPE = LAP
POSITION = 3f vertical uphill
AMPS = 85-95 AMPS
ELECTRODE = 7018 3/32”EXCALIBUR
TIPS:
