STICK WELDING CARBON STEEL 3/8" THICK 4F OVERHEAD TEE multipass 7018 1/8"
scroll down for settings
Did you know?..
METAL TYPE = CARBON STEEL A36
THICKNESS = 3/8"
WELD TYPE = Fillet weld MULTI PASS
JOINT TYPE = TEE
POSITION = 4F OVERHEAD
AMPS = 130 AMPS
ELECTRODE = 7018 1/8""
stick welding overhead
