90 amps is a pretty good setting for most brands of 3/32" 7018.
Some brands like Lincoln Excalibur might run better at 95 amps.
7018 rods are mostly used on Direct Current electrode Positive, DCEP aka Reverse polarity
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE
JOINT TYPE = BUTT
POSITION = 3G vertical uphill
AMPS = 90 AMPS
ELECTRODE = 7018 3/32"
