Stick Welding 5f tube to plate 7018 5/32" electrode settings
Scroll down for exact settings used
I got several requests for some 5/32" 7018 videos for structural welds so here is one for you.
Stick welding a tube to plate in the 5F position with 5/32" 7018.
5/32" 7018 are more difficult to run than 1/8" when making out of position welds like this.
Maintaining a tight arc length is key.
One thing that helps is if your welding machine has a feature called arc control or "dig" set it on a higher setting than normal while setting amperage at the lower end of the range for a 5/32" 7018.
The reason this helps is because arc control or "dig" setting is a feature that when set to a higher setting senses a drop in voltage when the arc gets tight and bumps the amperage up a bit.
This allows using a lower amperage without sticking the rod.
In this example, 145 amps was used with a 5/32" 7018
the amperage range for a lincoln excalibur 5/32" 7018 is listed as 130-210 so 145 was at the lower end but still worked for this 5f tube to plate joint.
scroll down for settings
Did you know?..
METAL TYPE = CARBON STEEL
THICKNESS = 3/8” TO 5/8"
WELD TYPE = FILLET
JOINT TYPE = TUBE TO PLATE
POSITION = 5F TUBE TO PLATE
AMPS = 145 AMPS
ELECTRODE = 7018 5/32"
ADDITIONAL SETTINGS = ARC FORCE SET TO 10 TO PREVENT STICKING
TWEAK AMPS AND ADJUST ARC CONTROL TO FIT THE SITUATION
