full version of this 6G video here
This was my very first welding test and I failed it.
6010 3/32" root pass can be tricky. It seems like you are either too cold or too hot.
hope this quick video helps
METAL TYPE = CARBON STEEL 2 INCH SCHED 80 PIPE
THICKNESS = .218" WALL THICKNESS
WELD TYPE = GROOVE
JOINT TYPE = BUTT
POSITION = 6G PIPE TEST uphill
AMPS = 65-70 AMPS
ELECTRODE = 6010 3/32"
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.
