STICK WELDING CARBON STEEL WITH 1/8" 6013 ON AC 110 AMPS LAP JOINT
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = FILLET
JOINT TYPE = LAP
POSITION = 2F
AMPS = 110 AMPS
POLARITY = AC
ELECTRODE = 6013 1/8"
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS. THIS DEMONSTRATION SHOULD GET YOU IN THE BALL PARK. TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
Did you know?..
