STICK WELDING CARBON STEEL WITH 1/8" 6013 ON DCEP REVERSE POLARITY 110 AMPS LAP JOINT
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = FILLET
JOINT TYPE = LAP
POSITION = 2F
AMPS = 110 AMPS
ELECTRODE = 6013 1/8"
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.
THIS DEMONSTRATION SHOULD GET YOU IN THE BALL PARK.
Did you know?..
