METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD ROOT PASS
JOINT TYPE = BUTT 3/32” GAP 3/32” LAND 30 DEG BEVEL
POSITION = 4G OVERHEAD PLATE
AMPS = 90 AMPS
ELECTRODE = 6010 1/8"
TIPS:
AMPERAGE USED HERE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
