STICK CARBON STEEL 3/8" PLATE OPEN ROOT 6010 1/8" DOWNHILL
If you need to weld a downhill root, this short video will get you started off on the right foot.
Did you know?..
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD  ROOT PASS 1/16 GAP, 1/16 LAND
JOINT TYPE = BUTT
POSITION = 3G   DOWNHILL PLATE
AMPS = 90 AMPS
ELECTRODE = 6010 1/8"
TIPS:   DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.
ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.
