STICK WELDING CARBON STEEL 3/8" PRACTICE PLATE DOWNHILL HOT PASS 3/16" 7010
scroll down for settings
Did you know?..
METAL TYPE = CARBON STEEL
THICKNESS = 3/8"
WELD TYPE = GROOVE WELD  HOT PASS  OVER 5/32” 7010 ROOT
JOINT TYPE = BUTT
POSITION = 3G HYBRID  DOWNHILL PLATE
AMPS = 145-150 AMPS
ELECTRODE = 7010  3/16"
This DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
