6013 rods are designed for welding on either AC or DCEP, or DCEN.
There are some slight differences with each polarity but not as much as you might think.
DCEN usually gets slightly less penetration so is recommended for thinner metals.
IF all you have is an AC stick welder like an old Lincoln Tombstone, that will work just fine too.
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = FILLET
JOINT TYPE = LAP
POSITION = 2F
AMPS = 110 AMPS
ELECTRODE = 6013 1/8"
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.
THIS DEMO AT 110 AMPS SHOULD GET YOU IN THE BALL PARK. TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
