solid or staggered and rest or no rest for the weary?
When making a coupon for a 4g test should the backer plate be welded solid or a series of staggered tacs? I've read that either is okay but I want to be sure.
Is it okay to use a jig that allows you to rest your elbows on a platform while making your passes?
I usually tack the ends only because the strap is easier to remove in the even I cut it off myself.
As to whether a platform is allowed to rest elbows on, I would recommend something like a c clamp that you might get away with in a real test shop environment at a job site.
Its not something you will be able to duplicate every where you go, but a c clamp might be.
