SELF SHIELDED FLUX CORE CARBON STEEL 1/8" THICK VERTICAL FILLET WELD NR 211 .035" wire
WELD PROCESS = SELF SHIELDED FLUX CORE
METAL TYPE = CARBON STEEL
THICKNESS = 1/8""
WELD TYPE = Fillet weld
JOINT TYPE = LAP JOINT
POSITION = 2f
VOLTS = 18-19volts
WIRE SPEED = 216 IPM
WIRE SIZE = .035” LINCOLN NR211
GAS FLOW = N/A
CTWD (STICKOUT) = 3/4”
FILLER METAL = LINCOLN NR211 .035"
TIPS: A longer stickout aka contact to work distance CTWD of 3/4” provides best results
