Scratch Start Tig .063" wall Sanitary Stainless Steel 6g welderskills settings
Scroll down for exact settings
Sanitary stainless tube welding is all about the inside and the purge.
Its nice if the outside looks good too but it can be polished after welding.
The reason the inside is so important is that bacteria can get trapped on a rough surface if the root is not purged well.
2 pieces of tool that will make your sanitary stainless welds go better are a dual flowmeter and a jazzy 10 ceramic cup
pictured below is the dual flowmeter, you can see it on my store here
scroll down for settings
Did you know?..
THICKNESS =  .063"
WELD TYPE = GROOVE WELD NO BEVEL
JOINT TYPE = BUTT
POSITION = 6G
AMPERAGE = 45 AMPS
FILLER WIRE = NONE autogenous
GAS FLOW = 20 CFH argon
CUP SIZE =  7
ADDITIONAL SETTINGS =    5 CFH ARGON PURGE
PRE FLOW = TORCH VALVE
POST FLOW = TORCH VALVE
Why scratch start tig?
The simplest and most portable tig welding set up is Scratch start TIG.
All you need is a DC welder, an air cooled tig torch with a valve, cylinder of argon, and flowmeter in order to have a scratch start tig rig.
But scratch start is not always the best option.
There are small inverter tig welders available that have features that allow tapering off amperage while maintaining argon shielding...without the need to snap out of the puddle which can be a great advantage when tig welding stainless steel sanitary tubing.
In the short video on this page, I used a DIY rectifier and old lincoln buzz box just to demonstrate what can be done with a very crude welder.
