proper gas
Mig weld with .035 ER70S-6 wire.12Ga. to 1/2" carbon steel. What gas should I use? I've been using 100% argon, but in some of your video's I've heard you mention a 75 25 mix. What should I use, and what are the differences?
wtt response,
you can either use straight C02 or a mix if ar/c02
75/25 .
pure argon does not give you a very pretty bead because it needs some reactive gas mixed in.
