I just got a chinese inverter 3 in 1 unit.
The first few welds on 4130 worked ok but,now my arc strays off to the side and wont puddle even at high amps. I ground the electrode correctly. I did run out of argon on my last attempt. What do you think? Other than I should not have bought a chinese welder. Thanks.
try again with a fresh tank of argon.
it sounds like a call to customer support is needed.
