PrimeWeld TIG 225x settings Videos
This first video on primeweld tig225x settings shows just how simple it can be
Scroll down a bit for video on Easy TIG settings
easy-tig-settings-2
primeweld 225 tig with stuff
This next video is setting up the welder and understanding torch switch and foot pedal settings.
I use a foot pedal most of the time but a torch switch can be very useful if you understand how to use the 2t and 4t settings.
primeweld 2t4t thumb
AC balance can be confusing but the video below will clear things up and help you get the most out of your AC DC tig welder.
If you want more advanced videos on TIG welding aluminum , visit welderskills.com
TIG welding an Aluminum lap joint with the primeweld tig 225x
the video below is a .125" thick aluminum lap joint welded using the pedal pumping technique.
aluminum-lap-brad-thumb-primeweld-tig
TIG welding .120" wall 4130 chromoly tubing with the primeweld tig 225x
primeweld-tig-225x-4130-yt-thumb
The Primeweld TIG 225x is a really good and affordable tig welder with all the settings needed to tig weld carbon steels, stainless, aluminum, titanium, and other alloys.
Te primeweld tig225 is priced like an entry level tig welder but it is much more than that.
It comes with a genuine CK worldwide 17 style tig torch with super flex cables and also a smooth foot pedal.
