PrimeWeld 225x Videos
Knowing how to use all the settings on the primeweld 225x or any other tig welding machine is a key factor in getting the most out of a welding machine.
primeweld 225 tig with stuff
Testing out the foot pedal on a primeweld 225x
aluminum-lap-brad-thumb-primeweld-tig
primeweld 2t4t thumb
Some of the most common settings to learn on any tig welder are...
2t 4t with upslope and downslope
pre flow and post flow
start current and end current
pulse settings like pulse frequency, background amps, and peak pulse
AC balance
AC frequency
and of course the main amperage setting and a feel for how much amperage is needed for any given job.
primeweld-tig-225x-4130-yt-thumb
The best way to learn about all the settings on your tig welder is to watch a video and then to get some practice.
But here is a quick tip for you to simplify things.
Unless you are going to use the torch switch, all you need to know about 2t and 4t upslope and downslope is to turn them all to zero.
All you need to do is make sure the 2t 4t button is set to 2t.
The foot pedal takes the place of all these settings so the whole first row of buttons except for main amperage can be just set to zero with a foot pedal pedal plugged in.
Primeweld 225x
primeweld tig225x banner 2
