holiday-deals-banner
Porosity/pinholes in mild steel
I recently started to weld vertical up butt joint with tig the root run must be in tig and the cap in mig so after welding the root run it leaves a lot of pinholes so i would like to know what am i doing wrong? Thanks
very likely, it is too much gas flow or too small a cup or some of each.
i have seen this before when using a small cup to get down close to the root...too much gas with a small cup causes air to be drawn in to the argon.
