Millermatic 252 Help with intermittent stops
by Larry Smith
(Mesa Arizona)
On steel side only, machine cuts out every 4 secs. Aluminum side is ok.
I think your best bet is go to the miller discussion forums . If it is a common problem, other users might have a solution.
http://www.millerwelds.com/resources/communities/mboard/
Comments for Millermatic 252 Help with intermittent stops
Jul 18, 2012
easy fix NEW
by: Anonymous
you have your spot timer on. Hold trigger and turn on machine to get into the menus and shut it off.
